Long-overdue update: After running my EG4 24K BTU (6 x 400w panels) and 12K BTU (3 x 400w panels) units all summer in off-grid mode only (i.e. powered only by the panels), and managing through the successive 15 + 30 + 60 minute waiting periods for the attempts to automatically restart the compressor and return the green light on the indoor unit after clouds had passed by and shut things down (and many times having to cycle power using the remote or app to get things back up after it ultimately never restarted automatically), I finally gave in and ran grid power to both units recently.
Observations:
a) As expected, the grid power keeps the MPPT constantly powered up, even when the PvInput goes to zero when clouds pass. It is a pleasure to not have to monitor the units for shutdowns and not have to manually restart them.
b) While running the AC Limiter, even during peak sun hours, the minimum AcInput draw I have seen is 40w on the 24K BTU unit; I sometimes see an AcInput draw of 0w on the 12K BTU unit while running AC Limiter.
c) As reported by MrM1 and others, the maximum inside unit fan speed while on AC Limiter mode is High (i.e. it will not allow Turbo).
d) I greatly prefer to run in Turbo mode, as the indoor air flow is much stronger (particularly on the 24K BTU unit) than the High fan setting. However, since the peak PvInput my 2400w of panels can generate for the 24K BTU unit is typically ~2100w (I have seen 2300w+ on very rare occasions), the unit will draw a minimum of roughly 640w of AcInput on Turbo mode (and much higher during non-peak sun). Interestingly, the 12K BTU unit often draws 0w of AcInput in Turbo mode (with PvInput in the 800-990w range).
e) Both units seem to typically draw considerably less PvInput than the panels / current sun level are capable of producing when running in AC Limiter mode. As soon as I change the Fan Speed from High to Turbo, the PvInput shoots way up (by several hundred watts). It would be great if the MPPT would fully maximize the PvInput draw during non-Turbo modes, but that has not been my experience. It appears that the only way I can consistently maximize the PvInput (while minimizing my AcInput draw) is to turn off my grid power (throw the breaker) and select Turbo mode. The downside to this is that the compressor shuts down when a cloud passes and I am then back to the waiting game for a restart.
As a result, I would love to see the app developers push out an update that allows the AC Limiter to run with the Turbo fan speed. This would seemingly provide the maximum indoor unit fan speed and the maximum available PvInput draw from the panels (and maximum cooling capacity of the unit) while limiting the the AcInput (~600w for the 24K and ~300w for the 12K).
P.S. These units are fantastic. The request above would simply make them even better.
