DIY Tools you'll Need:
XtremePower 3.5 CFM Pump and Gauge Set
- I used this but sent it back because the Gauges were pretty crappy and the pump did not seem strong enough ... but the A/Cs has worked perfectly for 3 months so I must have done it right.
I Replaced the Gauges with ...
Master Cool 59161 gauges
- Excellent for the DIY'er
- Made in USA
- I have since used these gauges to service 2 other A/C units for friends
And when I need a pump, I will most likely get ...
VIVOHOME 1/2 HP 5 CFM
- Yes the combo is less, but I think you are getting better product with these 2
Pump Oil
I got This
Reamer for the Copper Pipe, but I think the "Typical" Style Reamer might be better. But this worked fine for all sizes
Wostore Eccentric Flaring Tool Kit
- This is an excellent tool and worked perfectly EVERY TIME
- Make sure you put a drop of Nylog Blue on the cone of the tool for each flare
- Makes a very clean and perfectly shaped flare
Nylog Blue
- This is a MUST
- Put a drop on the Flare tool Cone before each flare
- and then a drop on the back of the flare between the nut and flare
- and a drop or 2 on the fitting
- Make sure you "smear" it in and around the surfaces
- This is a MUST to prevent leaks
Ridgid Pip Cutter
- You might want the larger one with the spring
- But this is a great Little Cutter
Vacuum Port Adapter
- These are the one's for 410a and the EG4 units
- Your size needed may vary
Extra PVC Wrap
- If you run out, or need more, or what came with the EG4 does not match your house color
Good Tape to Start and End the PVC wrap
- I used this tape to start and then overlapped so you did not see the tape
- Then at the end, I taped it and the taped end is up in the Line Set Covers
Various Size
Air Conditioning Copper Pipe Extension
- If you need to run the line set further than what you have
- I used these and worked perfectly
- You can get copper at a home center or AC supply house
- But if you have multiple units, Install the shortest run first, and save all the copper for the longer runs
- This is what I did and worked out so I did not have to buy extra copper
