Bowlegs868
My solar panels are grounded to the battery negative and there are grounds in both AC breaker panels (30A sub panel and main home panel) which are fed via a grounded AC plug from the inverter. The inverter is a "cheap Chinese" pure sine wave inverter and there's no manual for me to look at regarding grounding.
I have a new Victron SCC that has the chassis grounding point but after reading and watching YouTube videos I'm still confused as to what to do (grounding/earthing is annoying, I've decided).
What should I do with the SCC and what should I do about the inverter etc.?
