All depends on one's own requirements and budget. You and me obviously have more (20kWh and 15kWh respectfully).do you have only the one Fogstar battery ???
If so, it does not seem like enough.
Sounds a good plan. If you can get the rack nearer the Solis, all the better; if not, you will need to invest in thicker cables.Thanks SeaGal and Urge38,as said before all info appreciated and not going to rush.just didnt like exported energy but if battery fills i will definately get another as got the rack unit aswell!!
A single 5.1kWh is perfect for 'load balancing' out the clouds in the day and keep you going into the evening, especially if you cook with gas. As always it's a law of diminishing returns (ROI-wise).
And he can always add to the setup later in the year if demand and budget dictates.
Here's another UK supplier:thanks for replys,where would be the best place to source 4m battery cables and what size is recomended to connect the fogstar battery as need longer cable to reach where battery going to be thanks.Uk suppliers preferably??
If you download the BMS-Inverter-Protoco-HY.zip file and extract the files you will have PbmsTools.exe and a PDF file showing you how to set your protocol. It runs in Win 10 fine for me.
Edit: just tried the zip and cant see the pdf file, seems to be missing now.
Just spotted... fogstar actually now sell 4m long d.c. cables...thanks for replys,where would be the best place to source 4m battery cables and what size is recomended to connect the fogstar battery as need longer cable to reach where battery going to be thanks.Uk suppliers preferably??
Win 10 has its own unzipper, though I have winzip on my pc.I simply downloaded it from Fogstars web page, under the download tools, but it wont open
your computer must already have the tool to open it (say pdf, adobe etc etc) mine pc asked to Seach for a tool to open it and cant find one.
hence my question, if Fogstar could mention the tool needed to talk/understand there download language/file/programme (you know what I mean lol
Yes, you just need to extract the files from the folder, and then open PBMSTools.I simply downloaded it from Fogstars web page, under the download tools, but it wont open
Seems like a good time to get on the journey to 7.5p electricity 24 hours a day. Is the update to the inverter, or to the bms on the rack? Is it automatic or does the user install it?
