Cork Forest
- Sep 25, 2022
- 16
Hi All
I have a strange problem and I wanted to see if anyone has a similar experience and could offer me some advice before I blame my multiplus.
I have a small off grid home with ever little power consumption.
I have 3 Led bulbs (they are 230v E27) wired in there own breaker.
every time another load kicks in Fridge or water pump the lights all flicker off and on only once and very quickly. its not a constant flicker.
It seems like it takes a second for the multiplus to provide enough power to everything.
the total power is much less than the multiplus is rated for, I have perfectly sized cables on DC and AC side.
I have tried with a lamp on different circuits and same thing happens.
Could it be the Led bulbs or could it be the inverter taking to long to provide power causing the dip or is this just normal and something I need to get use to.
Thank you all in advance.
