What changes did you make?I made several changes to increase efficiency.
Micro aire easy start on our non inverter heat pump was the big one. That accounted for the major drop between February and march. Then electric on demand water heater. Will have to change that to an outside propane water heater or go back to the tank water heater with a timer. All lcd lighting. Still working on the garage lights. Sealing up any air leaks and put heavy curtains in front of the sliding glass doors leading to our deck. All in all it has helped quite a bit. Were having two doors replaced as they both are at least 1/2-3/4 inch too small for the frames letting outside air into the garage and then from the garage to the house.What changes did you make?
I know I have a kill-a-watt meter here someplace. I will find it and do some checking. Thinking of getting some of those smart plugs.Make a list of your appliances. Look up their consumer energy labels to get an estimate of consumption. Specs or nameplates to get peak power draw.
Some, like a refrigerator, may draw 800W for 30 minutes defrosting but only 200W intermittently the rest of the time.
Kill-a-watt meter can read power of 120V plug-in devices. Clamp ammeter can read power of any.
June is 300 kWh, July and August are 1000 kWh (looks like A/C).
What will your new winter consumption be? If you have other heat sources, and electric bill looks like June (10 kWh/day), then a typical system with as little as 3kW of panels should be sufficient. But panels are cheap enough compared to the rest, put in twice what you need or more, to make up for days without full sun.
The best loads use power while the sun shines. Enable water pump when battery full, etc.
Our AC and heat are a central heat pump. This is what the Micro air is on. Eventually I hope to supplement wit wood heat.Easy-start will help an inverter start it, probably doesn't reduce kWh reported on bill at all.
Instant electric water heater also won't reduce bill much, and of course is worse for off-grid. Tank type electric makes a good dump load. Propane take the load off electric.
Lights, sealing, insulation of course help.
But what is central heat? If electric, that's not practical for PV. Wood, coal, oil, gas of some kind.
Pollenface, Should what change would I need to do for accuracy?
