Hi
Hypothetical system is...
Diesel generator specs....
• 6.3kW/6300W (max) power output, 5.5kW/5500W (continuous) power output
• 27.4 amps max
• 1 x 230V 32A socket + 1 x 230V 15A socket
• 25L Diesel Fuel Tank
• 12 hours continuous operation @ 75% load
• Sound Level @ 7m | 92dBA @ full load
• Enclosed Canopy for quieter operation
• Built-In 2 Wire Auto Start/Stop System
Inverter is
Just roughly without worrying about losses and such.?
Thanks
Richard
• 27.4 amps max
Inverter is
Growatt 5kW ES
AC Charger- Charge Current 60A
- AC Input Voltage 230VAC
- Selectable Voltage Range 90 - 280VAC (For Home Appliances)
- Frequency Range 50/60Hz (Auto Sensing)
- NOMINAL VOLTAGE (V):51.2
- ENERGY (WH):24576
Max Continuous Discharge Current 150A Max Continuous Charge Current 100A Cycle Life 3500 (80% DOD) Internal Impedance ≤80mΩ Charge Voltage 56V Discharge Cut-off Voltage 44V Charge Temperature 0°C to 60 °C Discharge Temperature -20°C to 60 °C
Thanks
Richard
