Lawrence_craig
Hi all.
Hope my post title got you interested.
I have a 280aH lithium (DIY) battery connected to a JK BMS on my boat which is currently cycling unattended (i.e. I am away from the boat).
The shore power charging the boat typically charges the batteries during the day (along with the solar PVs) and then they turn the power off at night so the battery discharges.
All has been working fine (monitoring remotely) till recently whereby the shore power doesn't seem to be charging the batteries. So I suspect the battery is cycling and the BMS is cutting the supply off at the low voltage disconnect, then recovering slighting during the day with Solar PV.
I am trying to understand what this means for the batteries and really trying to work out if I need to jump on a plane to Greece to resolve it. Opinions welcome.
Thanks.
Thanks.
