Hi guys,
I recently bought a Titan solar generator and wanted to use Nissan Leaf battery modules to expand the capacity of my system, but ran into a problem due to ignorance on how to install a BMS. If the modules only had 2 terminals it would be a cakewalk, however there are 3 terminals because each Nissan battery module has 4 cells. 2 in parallel and 2 in series, which confuses things. When I saw the few videos on YouTube with a Nissan Leaf example, the general concusses was to add 2 red wires per module since they were already running in series. So since the Titan is a 24v system I needed a 24v configuration, I originally thought I would need a 6s 24v BMS, but after seeing people on YT only configure a BMS in 7s or 8s configurations I thought I would copy that (7s configuration) since I have no clue what I am doing or how they came up with wiring the way they did. However a 7s configurations come with some negatives, I would have to buy 6 7s 48v BMS's and a 48v to 24v Buck converter which has 95% efficiency. All of this would end up costing me $700+ dollars that I do not have, so if someone has a way to connect all 48 modules in a 24v system with 1 or 2 BMS's please share! Your wisdom would be greatly appreciated.
P.s. Can someone please tell me why when he attaches the 8th red wire on module 4 he moves the 6th red wire from module 3's positive terminal to the negative terminal of module 4 @ 7:25?
