D Danny1987 New Member Joined Feb 19, 2022 Messages 62 Feb 21, 2022 #26 timselectric said: Price, would be the only deciding factor. Click to expand... Just info: Just received some answers from buyers on Amazon. That linked fuse also works on 48 volt. And up to 160vdc, same as the other two.
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 20,097 Feb 21, 2022 #27 Yup
D Danny1987 New Member Joined Feb 19, 2022 Messages 62 Feb 21, 2022 #28 Any idea what battery cable size I should order? 5 foot distance at most from battery to the inverter.
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 20,097 Feb 21, 2022 #29 2 Parallel 1/0 cables for positive and negative. For 300 amp. Check inverter recommendations.
D Danny1987 New Member Joined Feb 19, 2022 Messages 62 Feb 21, 2022 #30 Disregard, found better options. Website description says this is a welding cable rated for 125 Celsius. Comes with 3 feet of heat wrap and few lugs. Would this work? WindyNation 1/0-Gauge 15 ft. Black/15 ft. Red Welding Cable Kit Includes 10-Pieces of Cable Lugs and 3 ft. Heat Shrink Tubing 10G-15B15R-10LG38-HS - The Home Depot The WindyNation Welding Cable Kit is ideal for installations that require cable lugs and heat shrink tubing. The Welding Cable Kit includes highly flexible and 100% pure copper welding cable, 10-Pieces www.homedepot.com Last edited: Feb 21, 2022
