Ok switch to sla and code is gone nowIf youre still not communicating you can set 32 to SLA
Run it like that awhile and see how things goOk switch to sla and code is gone now
Ok I will thank you so muchRun it like that awhile and see how things go
Goog evening I got the cable to work but now I am getting my a lot of 03 codes everything is coded to yours spec not sure what is going onJust set 08 to L16
I’ve had 0 problems with those associated values
I’d also cycle that battery a few times pretty aggressively
BatOpen Battery disconnected alarm, that doesn’t sound accurate. What’s the state of charge of your wall battery? Is 03 alarm staying on or is it intermittent? Do you have voltage at your inverter/batt lugs when the 03 alarm goes off or is your battery disconnecting? Need more info. Have you shut everything down and powered back up? Does it still throw 03? Are you still able go carry a load?Hello everyone I got the communication cable to work but now I am getting a 03 fault code not sure why
Good morning Lighthouse. So battery is fully charged when the 03 code comes up even when the alarm is on the battery shows 95% it stays on till I disconnect everything and reconnected ,code went off but it stayed in utility I just checked it 10:05 am 310 volts on pv and it hase not changed to solar first still on utility. All the codes are set to yous. Thae only things on the inverter is 2 fridge ac system inverter is at 40% loadBatOpen Battery disconnected alarm, that doesn’t sound accurate. What’s the state of charge of your wall battery? Is 03 alarm staying on or is it intermittent? Do you have voltage at your inverter/batt lugs when the 03 alarm goes off or is your battery disconnecting? Need more info. Have you shut everything down and powered back up? Does it still throw 03? Are you still able go carry a load?
Safe shutdown:
Good morning yes is all connected correctly I disconnected all and reconnected back this morning at10:05am I just got back home 12:43 pm and checked it it. Now it switched back to solar first no fault codes so far I will keep and eye on it and see what it does..Have you measured the voltage at the Inverter Battery Input? If your battery is charged and connected (properly i.e. not reversed or something) an 03 error would tell me something is wrong with the inverter. Particularly if it returns after doing a full restart as @Lighthouse Beacon indicated above.
yesGood morning yes is all connected correctly I disconnected all and reconnected back this morning at10:05am I just got back home 12:43 pm and checked it it. Now it switched back to solar first no fault codes so far I will keep and eye on it and see what it does..
This looks correct. Just run it. The only setting I have different than you at this point is I now run parameter 03 in APL mode, I have better performance this way. Other than that you should start running correctly nowGood morning yes is all connected correctly I disconnected all and reconnected back this morning at10:05am I just got back home 12:43 pm and checked it it. Now it switched back to solar first no fault codes so far I will keep and eye on it and see what it does..
thank you guys I really appreciate you all. Any suggestions on were to buy the pi. I saw a place somewhere it was running $180. All set upNow order your orange pi device and solar assistant and I’ll show you how to make this AIO unstoppable
Good morning happy Ester, check my inverter last night was working fine again this morning about 10 am everything fine just checked it at 12:00pm now I have 03 faults error again and running on utility. The second and third picture they keep changing code not sure if is because of the 03 fault code.Only way to get error out is to shut everything off and turn it back on any suggestions.Now order your orange pi device and solar assistant and I’ll show you how to make this AIO unstoppable
