Danyenah10
HI everybody , I am very new to this , I was planning on installing a solar system on the roof of a Mercedes Sprinter that would be capable of running a roof top air conditioner , I am toying with the idea of the following 3x350 watt 12 volt solar panels with 30amp fuses and blocking diodes then into 3 to 1 branch connectors then into a 60 amp mppt solar controller then into 2x 300 amp lithium batteries , I know it sound heavy but roof top air cons use a lot of amps …any suggestions on size of cable from the 3 in 1 connectors to solar controller .
any suggestions or advice would be greatly appreciated.
many thanks Mike
many thanks Mike
