MrM1
I'm Here, But I'm Not All There
I am installing 32 280Ah EVE cells in a 16S2P configuration. I have 2 225 Class T fuses on each battery bank wired to the parallel basbar with 2/0 wire. From the busbar I am running 4/0 to the inverter. I will be installing a Marinco Dual Bank Control Switch with a precharge resistor. The inverter is the big 12kw 240v split phase Growatt that has an on/off switch in it too.
Questions is, with the Class T fuses and the Switch, Do I Need a large 300 amp DC breaker? Seems the breaker would be redundant to the Fuses and Switch.
