Can someone test the t class fuses? For littlefuse (blue sea) and south bend?
gotbeans
Solar Cooking Beans
co/ar
I and many other people are interested in the south bend components fuses but there's not much info and zero tests on it
I was thinking of a way to test these fuses. I think putting some cheap lead acid batteries in series to 48 volt and putting a higher rated fuse or multiple in series and then the lesser rated fuse to be tested would be easy enough.
At lower amps we have bench power supplies but at higher we don't really.
Also interested in seeing the littlefuse "blue sea" being tested.
There are several other people that seem like they'd be interested in doing this. It'd not be the most expensive video.
Seems like a test for the youtuber styropyro but he's not here & doesn't really test equipment either.
This appears to be the only good test done with "higher" amp fuses, but it doesn't have t class ones:
here we see that the victron fuses are terrible and pretty dangerous vs their ratings. Which makes me curious about the other ones.
@KITROBASKIN
@eemarty
@Skypower
@undercrust
Sorry to tag anyone that isn't interested, but you all seem pretty interested in this subject and there has never been a conclusion. I have read a few years worth of threads and every mention of it.
At ~$40/each and much more there’s a bit of a price barrier to just blow fuses without sponsorship. No matter if I’m in feast or famine mode I don’t toss wads of $20bills in the campfire just to watch them burn.
probably a low-average video for testing equipment. Some videos cost thousands, but depends on how many views someone is expecting.
I'd easily pitch into a pool to have this tested. I think many others would too.
I got to test a 125a ANL fuse a couple of months back. Being distracted I was using one of my 3kW AIO's to use excess solar to heat water in the hot water tank. This pulls 2000w. While doing this I lost track and decided I was going to grab a lunch. I preceded to nuke a hot dog in the 1000w microwave that pulls 1700w. 2000w plus 1700w equals 3700w/25vDC=148a or above 125a fuse I had to my battery. It went pop very nicely and the AIO transferred to grid with a loss of battery fault.
In terms of circuit protection I would say it did exactly what it was supposed to do.
I belive the reason for Class T is if you have a short that draws thousands of amps. Can the ANL or Southbend break the circuit.
Yup. Even though it was an OHSE and not an actual fault. (Operator Head Soace Error)
I used the Class T 125A fuses on the 12V/100A BMS batteries because of the minute risk of sustaining an arc from LiFePo4 discharge in an actual fault. Shared power potential is 300A to the busbar but each 1AWG battery cable circuit is protected and “something bad” downstream would (should?) get shut down faster than a fire can start.
Like an insurance policy that prevents a loss versus a real insurance policy that costs more annually than the fuses but allows a payout only after you lose everything.
Not criticizing your ANL usage, just saying what I did.
As a USA company, the likelihood of South Bend using cheap knockoffs is low. They would be sued out of business by now.
It is a good question. Class T is definitely a good choice for the large 48vDc setups. A dead short I suppose is a remote possibility though I imagine the 160a MCCB I have in the circuit ought to take care of it.
There is also the fuse in the AIO and the BMS amp limit.
BTW, If my memory of the incident is any good (at my age of 64 it is not always) the fuse held for about 10seconds of the microwave operating.
victron ones have like 4 pages of certificates and ratings
They blow 50 amps higher than rated.
Pretty bad
Fuses and breakers have a wide range of trip/blow current. Depends on time and ambient temperature + cooling effects of installation.
I think magnetic-hydraulic breakers should be more tightly controlled.
But thermal protection responding to ambient temperature isn't entirely a bad thing.
These curves show a single line per fuse amp rating, but it is really a range from "guaranteed not to blow" to "guaranteed to blow"
DC testing is more difficult, hard to set desired current. Difference in performance is how arc is extinguished.
Midnight wrote a paper about testing polarized breakers in wrong orientation. They used a string of car batteries.
AC testing, easy to dial in desired current, at least for testing at reduced voltage. This won't be representative of arc extinguishing, but makes time/current easy.
What I did was I connected a transformer primary in series with electric radiator(s), and paralleled a Variac with another electric radiator. That lets me switch heating elements and dial in exactly the current I want.
Secondary has stepped down voltage, stepped up current. You can cascade another transformer for another multiple of current.
(The breaker curves shown there do have min/max)
I had three toroids I wired together, slow-tripped 100A breakers and fast-tripped 20A. Would need more watts of heater to get 1000A+ and fast-trip 200A breaker.
It is a good question. Class T is definitely a good choice for the large 48vDc setups. A dead short I suppose is a remote possibility though I imagine the 150a MCCB I have in the circuit ought to take care of it.
What are it's AIC ratings at 60V or above?
The fuses should be tested in their correct fuse holders. Yes, it matters. Oversizing the cables can also make them take longer to blow. Follow the manufacturers directions if they suggest cable sizes.
I would say undersizing cables and bad connections makes fuses blow faster.
The cable will serve as a heatsink for moderate overloads. High current where blowing is expected in seconds to a minute, shouldn't matter as much with a large thermal gradient along fuse element.
Wires get a hit of thermal stress when OCP blows. I've read the ampacity is designed for about 100 such events. A 50% overload takes maybe 15 minutes, and that current is 2x temperature rise (given enough time). For 14awg through 10 awg, allowed OCP is significantly lower than ampacity. These circuits are often used for multiple outlets, where homeowner is free to overload them and trip repeatedly. The higher ampacity should protect against damage.
As @Hedges mentioned you can't simply test fuses amp to amp without indicating the trip curve at least. It would be a bad design if you put in a fast blow fuse like in that video that tripped at exactly 100A. It would provide no ability for a surge like a motor to turn on.
Here is their spec listing for this class of breakers.
Not sure from the table if 25kA to 50kA is for multiple poles in parallel.
I often see voltage vs. poles in series.
Impulse 8000V
Are these ratings for AC, or for DC? At what voltage?
If the 25kA rating is for DC at your battery voltage, that's great.
Impulse 8000V
It is a DC breaker so I would imagine the ratings are DC based. As to the poles I would guess parallel would give the double rating factor. In series they should not gain anything.
I missed in the screen shot the voltage part of the specs. Here it is.
25k AIC at 250VDC is pretty good. Maybe even higher at your battery voltage although not documented.
That should cover a modest size lithium bank. I would use one pole per string if multiple batteries.
Class T will pass 200% rating for close to a minute according to the Blue Sea graph.
I would keep these a bit tight as they are short circuit protection more than for slight overload conditions.
What's their rating then if all of them pop at double the amps their number says?
& Yea I typically use a fuse for short circuit and breaker for overcurrent
what is this mystery breaker?
https://www.bluesea.com/products/5112/Fuse_A3T___Class_T_110_Amp
I think the idea is to provide for surge current for inverters or powering a motor direct.
Very fast to open at short circuit amp values.
It is what it is. Design the system accordingly. And yes if the ampacity of the wire is not well above the Class T rating there could be an issue.
Looks like Class T will pass 150% rating for close to an hour. This is by design. Again I prefer to keep these a bit tight.
Their rating is the amps their number says.
If you want precise control of over-current protection, get a remote trip breaker, use a shunt or CT to measure current, have a logic or microprocessor controlled circuit implement the time-current response you want. Then it could be within a few percent.
This is a thing for large systems.
At our scale, molded case circuit breakers take care of protecting wires. Electronics like inverters should have their own current limits to protect themselves.
Although I was a bit snarky with the Amazon-presented South Bend T-Class fuse listing (twice they refused my review submission questioning their legitimacy; said I could not have a question in a review. Problem was their Amazon listing was not allowing questions to be posed at the time)
I contacted the two RV manufacturers they claimed used this T-Class fuse; could not reach anyone involved in the manufacturing that knew what was used for a fuse. Then I checked repair parts. One pushed me to another company that was clueless. The other company had a helpful lady who spent quite a bit of time trying to track down the replacement T-Class fuse. Not sure exactly as this was several months ago but she told me the replacement part was Eaton(?) Littlefuse(?)
Do we know if that Amazon fuse has been UL Listed? UL Tested? Don’t know.
Could it be a shady operator using the South Bend Components name on Amazon? Maybe.
diysolarforum advise given to me when first questioning this was to not go cheap with protection, using known reliability…
Not willing to throw more money at South Bend Components fuses.
What I would love to see is AIC values of these BMS built DIY batteries and all the various connectors, to truly verify if class T fuses are overkill and at what voltage battery bank size is needed.
Start with a 280ah with 200a BMS in 12/24/48v configuration. Then double up batteries again and again until that ANL is turned into an arc light blinding your retinas.
Toss more economical fuses ANL, Mega, what have you) with a SCRAM kill switch to break the path in case the fuse isn’t able to extinguish the arc.
