Yes, like that. May have only been 2 fins.
Less expensive on eBay.
I was going to add 400A class T coordinated with 200A main breaker for catastrophic shorts, but decided box volume too tight.
So they will go on battery.
Also ambient and also if you have some sort of wind flow going on.
My ambient for some fuses ranges between 30 and 100 degrees which I only assume pretty massive for their ratings
I have to admit that immediately after watching this Louis Rossmann video I ordered the brand that tested best. I recently installed two new fuses blocks in a boat to replace the rats nest of inline fuses. The blade fuses were a collection of cheap assortments from Amazon and auto parts stores over the years and some looked kinda chinsy. There so many in the kit that I can afford to sacrifice a few in each range to verify performance. I’ve got a large selection of 5X20mm glass tube fuses I’ll doom while I’m at it. I’m going to try to use my internal resistance meter to see if there’s any correlation to blow current = non destructive testing = recategorizing. Sorry not going to blow $40 a pop on T class fuses. I do have a 5KVA variac and two turn microwave oven transformer so current isn’t the issue. One thing of curiosity, a littelfuse 300 amp fast blow has higher resistance and more voltage drop than a South Bend 250 amp fast blow when subjected to a 75 amp load. No much, a few milivolts.
If the fuses increase in resistance as they get hot, positive TCR, you should be able to find different curves for them without destructive testing. I'm sure that's easier to accomplish by first logging the curve for destructive testing. But it could be something like hitting with increasing pulses, using 4-wire resistance to determine element temperature, wait until cooled to same point for each step. Categorize according to current/time required for something like 50% resistance increase.
I did a simple test of automotive fuses to make sure they were marked correctly. The manufacturers did choose to use same element for two ratings, close enough to meet some tolerance spec:
After watching a video (sorry can’t find it now) showing resistance testing of cheap fuses and name-brand ones, I decided I’d better test the ones I’ve put in our cars. In the video, it was said that previously Harbor Freight sold fuses, but later recalled them and didn’t carry anymore. Fuses...
