set bulk, adsorb to same voltage....(the voltage recommended by YOUR battery manufacturer, not some one size fits all setting........your Outback is a bit different than my MidNite Classic, both were designed by Robin and Bob Gudgel so they both are “fully programmable” and similar in design,
Lithium's were not widely used then
Basically lithium does not need a bulk, adsorb,float,equilize charge parameters.
Bring them up to the manufacturers set point , let them continue to adsorb for 10-15 minutes then shut off all charging
Lithium batteries do not like floating.....bring them up to the set point is all you will need to do
It will be a workaround of the 4 stage charging that is programmed into the Outback programming.
Unfortunely it is not a good idea to remove the output of the charge controller from the battery when there is solar input. That will kill many controllers, it pains me to admit how i discovered that. If you must shut off the controller do it at the solar input.
Steve_S on this forum does have FLA batteries and Lithium batteries charged (not at the same time) with a Classic 250
He down loads a script to the Classic to do that. You might want to look at his system description and in there he explains lithium charging with the Classic.....again the Classic is the next evolution of the Outback....they were both designed before lithiums took off.....
