mikeytmh
Hi folks, I'm trying to design an off grid solar system with battery bank, for my well pump with pressure tank. It's 240v, draws 10A running (haven't actually put my amp meter on it yet), that's 2400w. It cycles on & off depending on the pressure in the tank (30 - 50 pressure switch). I plan on running a 48v system & 5kw split phase inverter (will that be sufficient) , so how many batteries & panels? although I taught electronics, solar is a new field for me so I need some of your expertise. I have no idea what hp the pump is as it was already there & works fine, standard household use (showers, dishes, cooking periodically throughout the day).
