JohnFranklin56
I am looking for a single 240v split phase solar inverter in the 6000w range that is expandable like the eg4 6000xp. The question is “will it start a 2 wire 240v 1hp motor“. Or a different unit that will work. Needs to have a very low idle current draw.
I have a 2 wire - 240vac - 1hp deep well submersible pump.
all measurements were taken from the breaker panel.
voltage 239 volts
Inrush current is 22.85 amps
max running current is 10.53 amps
normal running amps is 8.79 amps
Will, it would be nice if you could test different inverters on starting a 1 hp well pump. There are a lot of people who have wells and starting a induction load can tap out a lot of inverters. It would make a great video. Thanks for all your help!
voltage 239 volts
