pegleg pete
i am running a 1hp 240 well pump 800 feet from main home panel..will 2
EG4 6.5kW Off-Grid Inverters | 6500EX-48 and 3
EG4 [LifePower4] 48V 100AH Lithium Batterys run this pump.. the wire size is #10
no idea what a soft start is..i agree it shouldn’t be a problem to run that load but a soft start could be used if a problem arises
His pump is only a 1 hp according to op
Interesting if you can pull up the info from the archives (if you remember) it would be good to get the information, always learning it seems like there’s something that throws an wrench in the works even on the best of plansI understand as I made calculations using 1hp. Unfortunately, my failing memory can't recall the details, but the nature of the pumps operation and installation (which was typical for the type) prevented use of the soft start.
Doesn't hurt to have the OP ask though.
will this work..INRUSH function of a clamp AC ammeter?
1 hp motor, no problem.i agree it shouldn’t be a problem to run that load but a soft start could be used if a problem arises
will this work..
Klein Tools CL700 Autoranging Digital Clamp Meter, TRMS 600Amp, AC/DC Volts, Current, LoZ, Continuity, Frequency, NCVT, Temp, More, 1000V,Black/Orange
800' and #10 AWG wire? We need to know specifics of the pump to calculate voltage drop and required wire.
Fail on my part. Thanks.Post #2
800' means what? the well is 800' away from the house, or the pump at the bottom of a 200' well is 600' away from the house?i am running a 1hp 240 well pump 800 feet from main home panel..will 2
800' from house ..or main panel..800' means what? the well is 800' away from the house, or the pump at the bottom of a 200' well is 600' away from the house?
What I have read is that soft-starters are NOT a good idea for submerged well-pumps. As I understand it, lubrication of the pump bearings is with the flowing water itself, and soft-starters making the pump initially spin more slowly, with more wear on the bearings.i agree it shouldn’t be a problem to run that load but a soft start could be used if a problem arises
