ericfx1984
- Oct 10, 2021
- 741
An issue that I've noticed is that if my system is charging on a cloudy day with the sun peeking out from time to time and I'm not using a lot of energy that occasionally when I get up to the very top end of charge my inverter will disconnect due to high voltage
I have a pair of lithium iron phosphate batteries... Each with a 200 amp BMS (I think jbd?)
I also have multiple charge controllers in the mix
What I think is happening is that the battery voltage is reaching the maximum voltage per cell or possibly per pack... At which point the BMS disconnects the charging side of the battery which causes a momentary jump in voltage or split second, this temporary increase in voltage that lasts until the charge controllers recognize the full state of charge
My thought is that this is not noticed when I'm actually actively running a load, such as an air conditioner, because the act of load creates somewhere for the momentary increase in voltage to go... As such it remains unnoticed
There's a couple ways that I think I could solve this issue
One would be to lower the overall battery charge voltage coming out of The MPPT charge controllers
The other option might be to increase the maximum pack voltage before disconnect in the battery management systems
I could really use some help on this
