If you’ve been running for a year, when was the last time you top balanced? Otherwise there’s a high chance your cells are just unbalancing themselves. As it unbalances You’ll eventually need to drop charging voltage again and again.
Once you build you’re 48v system a proper top balance maybe in order.
Absolutely I plan to... I have another set of 280 amp hour cells that will be going into 16S that I'll need to do a top balance on
At that point I'll be able to decommission this system...
It won't be a total decommission but it will be a major scale back
Currently I have 16, 304 amp hour, Eve cells set up in 4P4S running on a single 200 amp BMS
Then I have eight, 230 amp hour, Eve cells running in 2P4S also on a single 200 amp BMS
Basically the plan is to take the 304 ah cells , give them a good top balance, reconfigure them into 16S, and put them on a 16S, 200 amp BMS
The RV will be pushed down to a pair of 4S, 230 amp hour batteries
So basically when the house is done we will have a 16S, 304 amp hour battery and a 16S, 280 amp hour battery
