I have an Aims 24v 3000w inverter charger with a 420ah battery bank. Everything works great either in inverter mode or when the inverter is in charge/bypass mode with my Yamaha 3000efi inverter generator.
When I use my air conditioning unit (it has a hard start kit) in inverter mode the system works well, pulling about 64 amps. When I start my generator, my inverter kicks out and goes shows "Over load Alarm" and resets back into inverter mode. Of course since my generator is still running, after a few seconds it goes back into charge/bypass mode and does it over and over. If I connect my generator directly to my RV, the AC runs no problems.
Any thoughts of what can be causing this? I’m in contact with Aims but they aren’t too sure either and are suggesting things for me to try, which I`ve already performed.
