Thanks to all of you for your interesting posts, I'm learning many things.
Just to update, after some research, I'm attracted by the Enphase IQ8 series.
It seems suitable to what I'm looking for, with the ability to provide emergency power without the need of any battery when used in conjunction with the IQ system controller.
I've found really useful informations here :
Learn how Enphase Energy Systems can be customized to meet your solar + backup power needs.
www.gogreensolar.com
Our Enphase IQ8 review explores the new Sunlight Backup feature, which promises "backup without batteries." Let's find out if the IQ8 live up to the hype.
blog.gogreensolar.com
The only real downside to this solution in my opinion is that from what I understand, if I later decide to add a battery, I'll have to go with an enphase battery. But I can live with that.
What do you think ?
I also have a question about something I don't quite understand regarding the power of those inverters (same thing with IQ7 serie).
I can read everywhere things like "The IQ8+ micro inverter from Enphase are designed to handle 235 to 440 watt solar panels."
But when I look at the technical data here
https://enphase.com/store/microinverters/iq8-series/iq8plus-microinverter
It says "input power : 235 - 440+ W, Maximum continuous output power : 290 VA"
But if the max output power is 290VA, that means that I'll never be able to fully exploit a 400Wp during a sunny day, right ?
Then for a 400Wp panel I'd have to go with something like the IQ8H, which have a max continuous output power of 380VA, which is the closest of all the series, right ?
Is that misleading or am I missing something ?
Anyway, I'm attracted by this solution because to me it seems to be the best one in term of function vs cost.
The upfront cost is quite high, but since the inverters come with a warranty of 25 years, compared to a string inverter that have a lifespan of 10 to 15 years (from what I understand), it's basically like cutting the cost in half in the long term. I've read that the efficiency might be a little bit lower but I can live with that.
What do you think ?
Thank you for your help
