32 volt boater
- Aug 7, 2022
- 427
As it should be as that is a 15A receptacle.I have both on my inverter but was told the receptacle was limited to 15A current.
It can be a 20a as well.As it should be as that is a 15A receptacle.
?As it should be as that is a 15A receptacle.
Yeah, bit if the receptacle is limited to 15A then it shouldn't be a 20A receptacle- the assumption would he made you could plug an appliance in that pulls 16A and uses the 20A plug, and it would not support it and would trip.It can be a 20a as well.
True, but if say the inverter is 3000 watt inverter, no reason is should/ could not have a 20amp proper like.Yeah, bit if the receptacle is limited to 15A then it shouldn't be a 20A receptacle- the assumption would he made you could plug an appliance in that pulls 16A and uses the 20A plug, and it would not support it and would trip.
Most likely saving a nickel.I agree. It seems lots of these inverters only have 15A receptacles for some reason though.
