Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,682
Of course, you may get away with it, if temperatures aren't too cold, PV panel Voc runs a bit low, SCC has margin above spec.
To be safer, you could get another SCC, use it with a single panel and use your existing SCC with two panels in series, "2s"
That also gives redundancy, in case one SCC dies for any reason.
Since dimensions are small, wiring 3p could be an alternative, if it doesn't violate max input current specs.
That might harvest more power, MPPT more efficient if voltage conversion is less.
However, in a hot environment, Vmp might drop below minimum input voltage of MPPT. I think "2s" or "2s2p" is optimum for efficiency and voltage margin (both high and low.)
