Is it ok to pass ac in battery cables in the same raceway for one meter?
Blackmoses
I’m moving the inverter to an adjacent room. Is it dangerous to pass the (AC in cable) + (pv wires) + (battery cables) in the same pvc raceway for only one meter?
I need your advice please.
Thanks.
The system is off-grid
Inverter Growatt 5000es
8 solar panels in series
battery 200A x 2
As long as the insulation rating of all cables is greater than the maximum voltage they ever see you will be fine, for example most network cable is rated for at least 300 volts.
Thank you soooo much. I was very worried because I’m new to solar.
Many thanks you and for ‘Will’ for this forum which my refuge.
