hipringles
- Jan 31, 2021
- 214
Can SA read multiple JBD bms at once?
Just tried through a Growatt Rs485 hub and still can only see one JBD at a time, with hub hooked to separate usb on Pi4b i get invalid data with both Jbd's hooked to hub, one at a time works. Anyone have tis working yet?The most recent Beta version allows multiple JBD bms at once. From SA website:
2022-03-02Beta
New features:
- Support for multiple Daly and JBD BMS connections.
Yes as of SA build 3-2-22Can SA read multiple JBD bms at once?
Curious. With multiple BMS on different ports (6 in my case) how does it display the overall battery SOC? Does it aggregate the configured and remaining AH for each BMS? I have 2 running 230ah and 4 running 280 ah.
This may solve my need for a separate shunt that aggregates all batteries.
not aware of any off the shelf stuff that does this.My JBD bms only has the uart port. Is there a way to have a splitter so I can have bluetooth and rs485 going to SA?
as mentioned above, the components for the actual interface may not be present on the circuit board, which may thwart the effort.My jbd bms has A and B pads for rs485, but there isn't a connector. Could I just solder this to those pads?
https://www.amazon.com/gp/aw/d/B088FX3S8J/
