MrSurly
- Nov 20, 2020
- 17
Just as an FYI, the make step isn't really necessary unless you want an executable. It uses pyinstaller, which just bundles python and the scripts into an ELF. On Linux, this tends to be very large, so I only use it for the Windows releases.
Doing "pip install .[gui]" should make the GUI available from your standard path (after re-opening your terminal).
The GUI install will compile wxpython if your distro doesn't provide a binary package for that, hence the long build time.
