JBD/Overkill BMS CAN bus comms support for inverters
So, if I understand correctly, I would need 4 of the $199 boards if I had four 12v 280ah batteries in series each with its own bluetooth JBD BMS?
Yes,
The JBD comms is tied to Battery negative so the communications need to be isolated between BMS, else the magic smoke will escape when there is a protection and the FETs isolate the battery.
Regards
