Ok, STI3470. That one should be fine. I would suggest replacing them all. One of the issues with the original chips in some versions was that they had a 500kHz chip instead of a 600kHz one, and that messed things up. I had a similar situation where the output voltage was fine, yet the issue was fixed replacing the component. I'm not saying this is definitely the case, but if you have them, worth a shot.
There could be another chip that needs to be replaced when this issue occurs. I need to go check my notes, it's been a while...
