Sinosidual
- Mar 20, 2022
- 1
Good morning,
I recently got an inexpensive 10A 30V PSu to top balance Lifepo4 cylindrical cells. I was able to balance them at 3.65. However:
The display voltage fluctuates a little by .01V. This happens even if nothing is connected. For example, with nothing connected, votage may fluctuate from 3.65 to 3.66. This was confirmed with my multimeter. It really jumps around in the thousandths place!
In practice, while in CV mode, the amps will approach zero, then go up a little while there is a small voltage increase.
Is this behavior to be expected on an inexpensive unit? Should I return it?
Thank you
Link to the unit:Longwei Supply
Thank you
