Withered+Flame
I am getting massive, volt large voltage swings with my overkill solar 48v bms when charging 25a from my chargeverter.
I am charging with 57v 25a from my chargeverter.
Bms:
Chargeverter:
Ring terminals:
Cells:
Buss bars:
See attached. Mainly the last 2.
I can't imagine this being good for my battery or bms.
I did top balance the cells.
Any ideas on how to stop?
Edit: Is there a way to slow down the current? I think if the current came gradually and not all at once this would not happen
Bms:
16s BMS 100a for LifePo4 with 12″ 8ga Wires
Comes with 12 inch long 8ga wires soldered to the board as shown. BMS For 16 cell, 48v volt Lithium-iron-phosphate DIY batteries 100 amp continuous charge or discharge current Low Temperature Charg…
overkillsolar.com
EG4 Chargeverter 48V 100A Battery Charger | Current Connected
Revolutionize the way you charge your batteries with the EG4 Chargeverter - a cutting-edge 48V charger boasting a charging capacity of 100A or over 5kW!
www.currentconnected.com
Cells:
Buss bars:
