@sunshine_eggo
the contact is also made by the thread itself and the top surface of your busbar (via the screw head lower side).
Last picture on the right side => egg shaped
you didnt understand!
the original terminals should be hex-shaped (instead of egg-shapped) and some 10mm taller, so you can hold the terminal with a wrench while tightening the screw
Even if you count it, it's simply better to have more surface area between the terminals and bus bar.
yes they are far too low profile. Should be standing up from the casing at least some 10mm. Then a flat wrench would work. Or as I say a 90° strip standing up then you hold the screw head from the other side and tighten the nutYes, terminals you can restrain with a wrench would do it. Most we've seen were so low profile you can't even put a DMM probe on it to measure voltage drop across interface. Just a 1/4" tall square terminal should do it.
I would prefer a stronger material (e.g. stainless steel) clamping cell terminal to busbar. And suitable surface treatment. Maybe tin-plated aluminum terminals.
I still say it ain't surface area you need, it is clamping force. Only a few high spots actually make contact, and more area less pressure results in fewer spots contacting. Bolting mechanism that allows higher force achieves more contact points.
both!Ever heard of perspective? All of them are.
Do you have a point, or are you being petty and criticizing my "artwork" because you have nothing meaningful to contribute?
Both! and you still need e.g. Wago Alu Plus paste if it is AL!I still say it ain't surface area you need, it is clamping force. Only a few high spots actually make contact, and more area less pressure results in fewer spots contacting. Bolting mechanism that allows higher force achieves more contact points.
both!
egg = circle! Can you hold any round shape with a wrench?So, you feel the need to point out that circles appear as ellipses when viewed from an angle (something any reasonably intelligent person already knows), and my shitty artwork.
Awesome. You bring so much value to this discussion.
I'm going to assume you're not a total ass, and English is not your first language, so you just come across as one.
Eve said it's in place of the the threaded female post not an add on like the stud is.that thing seems still to be some "add on" on top of the original terminal with screw hole. I would not trust the connection between the two.
Best would be as I say a strip of thick aluminum with 1-2 lateral holes standing up and made from one piece of aluminum with the base.
My screws are aluminum, no washer.Not worth considering since this is common among all methods. This is also lower conductivity due to stainless bolt and non-copper washer.
wont grab it.
because Battleborn = clue.But I agree, a post like battle born has would be ideal.
Ya, I am sure most of these type of cells are going into packs that have everything welded together to eliminate assembly errors and longevity where the cells fail before the connections.because Battleborn = clue.
Sometimes I really ask myself if many of these chinese manufacturers ever test their products. I assume in practice most of these batteries go into some pack production and finally are anyways welded, but not connected using any screws. So shitty terminals doesnt matter to them
