Hello everyone,
Exciting today I received my Growatt SPF 5000 ES Inverter. I spent a good amount of time reading posts on grounding but I haven't found a similar configuration with a confirmation.
My house has a brand new main electrical panel. It has a 18mm (I think it is like a 6 AWG) insulated ground going outise to a copper water pipe. From that ground/wire pipe connection to the street copper pipe I have a resistance of 4 homs so I believe I have a pretty good ground for the house. Also tested at home with a plugin ground tester. As you can see in my diagram from the roof panel to the combiner box, to the AC output panel to the Growatt everything is connected to the same house ground. Is this a safe configuration? I am relectant to add a ground rod and cause a ground loop. Thank you in advance.
