Jorvs
- Feb 21, 2021
- 14
I mean do do this while its on a 12v series?You are 'shorting' current through the bulb to take power out of the cell and lower its voltage. The bulb limits the amount of current.
You need to take care that your 'test probes' on the wires to the bulb are suitable, this could be as simple as a few mm of the cable wire core that you 'prod' on the cell terminations or the buss bars to the cell.
As you lower the charge on the cell one of the others may become the 'high cell' so you switch your attention to that.
It's a bit like 'wack the mole', keep moving the load to the high cell for a few seconds when that cell becomes the cell with the highest voltage.
When working with cells take the usual safety precautions using eye protection, no metal jewelry or rings, insulated tools.
Mike
and do stop the charging while doing it? or do stop the charging first?
