It doesn't take a breaker failure to cause a lot of damage.
The way it was explained to me is that you can run an arc welder at less than 100A.
So if your breaker is 100A you can get one hell of a welding arc going before the breaker trips.
If your flashing sparking melting experience never reaches 100A it never stops welding because the breaker doesn't trip.
That probably makes a lot more sense after you have experienced a short.
An arc welder is basically a short that is lower amps than the breaker
Hey, it's not as bad as Lipo
