Ariel188
The hot water is propane but I keep it off until needed and do not use the electric heater for it.Just wanted to comment on a couple of the above in case you're not aware:
1) if your hot water heater runs on propane (can't imagine it doesn't), make sure you run it on propane (turn the W/H breaker off). This is an energy hog and will empty your batteries pretty quickly unless you manage it diligently.
2) food: If your fridge can run on propane, it is critical that you run it on propane. If you run it on AC power, this type of fridge uses 5-6X the electrical energy of a "normal" household fridge and will absolutely empty your battery fast.
The stove is electric only, no propane. Its a grand design 390 rkr. (stand for residential fridge) but does it look pretty thou and not like an RV fridge, looks like one in a real home. I didnt realize having a propane fridge would have been nice. My van will have 12 volt. No propane in it at all.
This generator he brought stopped working too.......he brought another one jus tlike it today and so far so good......why do none of the generators wanna charge my batteries..? maybe something still bad with wiring. I get mine from costco on thur. It better work!
