Actually, I think I'm mixing 271 with 272. 271 is medium strength, 263 is high strength (and so is 272).
In any case, either will do, one just needs a primer.
It's not 'obsolete' as far as I know. It has certain properties (like needing a primer) and it will still be available (as far as I know, it's still produced).
It's just that 263 is easier since it doesn't need a primer and covers the same use cases that 271 does.
I’m gearing up to secure my first stainless grubscrews into aluminum 280Ah terminals with Loctite Red and see that the instructions state that Primer is needed when both surfaces are ‘inactive metals.’
Stainless is an inactive metal and so is Aluminum, so it seems like primer is required.
But I believe I’ve heard from many who have used Loctite Red on this board that primer is not needed if you have cleaned the threads with Acetone (which I have done).
So advice for a Loctite-newbie appreciated - do I need to bother with primer after threads have been cleaned with Acetone and dried?
Any ideas where i can find the Loctite Primer N 7649 locally? Amazon shows delivery in about 2 weeks. Im in Dallas and not finding it so looking for better search suggestions.I used the primer on my stainless studs. I found the the red dried and became safely fastened much faster with the primer. Also, I found JB Weld does not hold nearly as well.
I ordered some off of Walmart.com ...... don't remember how long it took to get it.Any ideas where i can find the Loctite Primer N 7649 locally? Amazon shows delivery in about 2 weeks. Im in Dallas and not finding it so looking for better search suggestions.
First one I tried did not set in 24 hours. It does if you use the primer.I’m gearing up to secure my first stainless grubscrews into aluminum 280Ah terminals with Loctite Red and see that the instructions state that Primer is needed when both surfaces are ‘inactive metals.’
Loctite 263 is made for studs and claims to be primer less. https://www.grainger.com/product/LOCTITE-263-Series-High-Strength-Primerless-5HYJ0
Primer can be used if you want it to cure faster or if it makes you more comfortable.
Mine dried hard as hell after a couple days without primer
