iamrich
Anyone know which control board monitors the battery voltage inside the LVX6048? Not sure if I caused it, but after hooking the Lifepower comm hub to test, the battery voltage is all over the place (-2 to +6v). I unhooked the hub to see if that would fix it, but no luck. Right now, my voltage is 53.1v on the six pack of lifepower4's, but if the AC comes on, the LVX6048 drops to 51.3v. Once the AC goes off, the voltage jumps to 55.3v. It's not a huge deal (well maybe it is), but I have to set the float/bulk values higher and higher or the solar array stops charging. My second unit (independent, not paralleled) is working fine.
