rodrick
Free energy enthusiast
Have you looked into a standalone pump/controller no battery needed like the RPS 800 if you have some used pannels to spare the system is a approx 1500.00 without the panels that is what I am going withAbout 260ft
When this one dies I'll replace it with something more energy efficient, maybe something that can do AC or DC (Groundfoss?), but that's a lot of money to replace the pump, tube, fittings, etc. Getting 300ft of lift is fierce! That and sunlight out there is minimal at best.Have you looked into a standalone pump/controller no battery needed like the RPS 800 if you have some used pannels to spare the system is a approx 1500.00 without the panels that is what I am going with
Almost out of Data for the month so can't do a bunch of research till the 6th. Needing low temp protected batteries adds to the cost. It struck me that most well houses need to be above freezing to protect the pipes. Is this taken into consideration?OK @Mattb4 ready for a real challenge? I got a noodle project for ya! (Sleep debt may be involved so...)
HAVE:
8-ish old 200w panels, ~37Vmp and 6-ish amps
Plenty of wall space
Wire, crimps, hardware, etc.
40a SCC 12/24v
NEED:
3Kw+ of 240v Split Phase power, low frequency
~2Kwh+ of storage + overhead
COLD Protection!
CHEAP!!!!!!11111oneoneone (So no Victron)
WOULD LIKE:
30a+ step down converter to 12v, but no objections to the current 2x 100Ah FLA setup I have now as a separate system
24v based so I can reuse the 40a SCC
Not picky about 24v or 48v, just needs to run the well pump for an hour a day worst case scenario. About the best I'm coming up with is:
2Pack 12V 200AH Plus Low Temp Cutoff LiFePO4 - $1100
Sigineer Power 3000W 24V Pure Sine Wave Inverter Charger - $850
F.S.P 150 Amp MRBF Terminal Fuse 150a - $25
DC 24V Step Down to DC 12V 30A 360W - $23
ECO-WORTHY 4 String PV Combiner Box - $75 (Have to do 2s4p to that SCC)
Or, in the 48v world:
FOIIOE VESTWOODS 48V 100Ah - $1350
EG4 6K Off-Grid Split Phase Inverter (Refurbished, discontinued?) - $1100
OR
6000W 48v Hybrid Solar Inverter 120V/240v Split Phase - $1200
80 Amp MRBF Terminal Fuse - $25
So it looks like 24v is slightly cheaper ($2075 VS $2575) because I can re-use the MPPT controller feeding the current 12v system.
Of course if I was insane I'd stick with a 12v setup:
SUNGOLDPOWER 4000W 12V Inverter Charger - $1000
HQST 60 Amp MPPT Solar Charge Controller - $220 (in parallel with the 40a in there)
FBL-300 300 Amp Fuse Class T with Block - $90
For a grand total of $2410, about smack dab in the middle.
Can you do any better?
Yes, but the place gets below freezing every year for months on end. I'll be installing another diesel heater in the pump house in a week or two (when I can FINALLY get up there!) but I'm paranoid and the low temp protection is cheaper than new batteries.Almost out of Data for the month so can't do a bunch of research till the 6th. Needing low temp protected batteries adds to the cost. It struck me that most well houses need to be above freezing to protect the pipes. Is this taken into consideration?
Yeah, that's what I've got now but it burns a gallon of gasoline an hour at idle and I'd like a backup that doesn't require fuel. That's why I've been looking at a small system with a LF inverter, something that only needs to run for 15 minutes a couple times a day and can just sit there floating the rest of the time.Based on all your comments concerning the well I would not recommend a PV/battery solution. Sounds like the place for a propane fired generator and a 100lb tank (if you can not get delivery of propane) or smaller depending on your ability to handle it.
Ideally you would never run your generator at idle. With a electric start generator you start it to run the well pump and shut it off when you have pumped adequate water. Many folks that go this route put in above ground water tank so that they can use a smaller on demand pump (here's where PV/battery comes into play) for pressurized water. However you could use the generator to fill a large pressurized storage tank as another setup.Yeah, that's what I've got now but it burns a gallon of gasoline an hour at idle and I'd like a backup that doesn't require fuel. That's why I've been looking at a small system with a LF inverter, something that only needs to run for 15 minutes a couple times a day and can just sit there floating the rest of the time.
