Hi guys. I was wondering when measuring current from the solar panel into the inverter with a clamp meter. Are you supposed to measure the positive or the negative. I always measure the positive but it shows a higher current than the negative. I got an Axpert vm IV twin 4kw. The inverter screen also shows me a lower current from what i get when measuring the positive line with a clamp meter.
And how does one update the firmware of axpert inverters? Thanks in advance.
