KBWaldron
Most of the manuals mention not mounting on flammable materials, which tends to rule wood out. Metal seems obviously a non-starter. So what are people mounting their mppt, breakers, inverters, etc. to?
Use a layer of cheap drywall over your plywood.It bothers me to mount to plywood also, but it is so easy to work with. Does anyone know of a very good fire resistant paint? It would be better than nothing.
Dry wall is messy, cut edges with all that dust, needs to be taped, I'd use it if I was afraid my system was going to go up in flames. Or maybe I should just stay connected to Pg&E?Use a layer of cheap drywall over your plywood.
Cuts with a razor blade scoring and snap.
Oh wait, don't they set everything on fire?Dry wall is messy, cut edges with all that dust, needs to be taped, I'd use it if I was afraid my system was going to go up in flames. Or maybe I should just stay connected to Pg&E?
Rockwool batt insulation would address that.I wasn't all that concerned about what it was mounted to. It's only a couple feet below my ceiling joists, which is where the flames would go.
