carterjohnsons25
- Mar 26, 2021
- 41
HELP PLEASE: Need Ninja Knowledge:
I am Making a 96cell Eve 48v Battery -1200lbs. ~85kWh
My uneducated knee jerk is following
Multiple packs in parallel
PROs - has benefit of any one pack going bad and you can just shut it down. You are still good
CONs - Balancing with charging? How to monitor 6 48v modules
Massive Single pack
PROs - single BMS for balanced charging???
CONs - Massive high amp BMS, Many single points of failure. one cell bad could Drain or kill pack.
Thank you in advance.
- is it better to make one Massive Battery. IE 6p16s with 1 single 500amp BMS
- Make 2 48v Modules 3p16s each with a 250amp BMS, then put these two modules in 2p configuration. ... or some variant of this. Such as 3 48v modules in 3 parallel
- Make 6 16s 48v modules each with 100amp BMS for each individual module, then connect all 6 modules 6p configuration.
Massive Single pack
