Oh, I have 16 280Ah Lifepo4 (same battery model bought in 4 units in 4 batches....in different time). Therefore each 4 batches have different SOC. Few weeks ago, I finally bought Growatt SPH 6000 ES Plus and JK-PB2A16S20P which has inverter communication. I selected “LI” in Program 5 and using RS485 communication protocol. However, JK-PB2A16S20P has a bug and that is, if
any one of the cell reach OVP, it switches the SOC % to 100% and sends a signal to Growatt to stop charging. It never go into "float" mode and the charging simply stop. Thus, the built-in 2A active balancer and Heltec 5A never have much chance to balance at 3.45v. Currently waiting for JK to provide firmware update fix at end of the month.
There are one batch of 4 cells get fully charged first (which was top balanced) before other cells. My dedicated charger decided to off itself on my 5th cell leaving me with 14 non-top balanced cells
I stumbled upon this forum and read few threads that suggest user to set Growatt Prog 05 to USE mode, Prog 19 to 56.0v and Prog 20 to 55.4v instead of the BMS-Inverter communication.
JKBMS only balance 2A by transferring current by one cell to one cell. Meanwhile, Heltec normally balance by 1A-2.5A depending on voltage deviation as measured by my DC clamp meter.
I set the JKBMS to shut off discharge at 2.8v per cell and growatt will switch over to utility automatically. I make full use of currently available capacity. It just that the balancing kinda........take forever........one of the 14 non-top balanced tends to trigger LVD (only 0.025v deviation between those 14 cells at 2.8v, the 4 top-balanced cells voltage are at 3.1v)
I shall follow your advices in using all three balancing functions. Use Neey to balance at 25mV and JK to balance at 10mV. Guess I will disconnected the voltage trigger relay at Heltec and use manual switch as you recommended.
There is one question on the balancing part. When people mention 2A, 5A and 10A active balancer, what is the wattage being transferred? P= I x V. What is the voltage? Total pack voltage? Or individual cell voltage? I searched around the net and I never really find out answer to my question.
