Multiple battery
I thought I might buy the cables with connectors on them. Another thing to figure out.
Thanks
They'll either be too short or too long. :) You never really know how long a cable needs to be until you have the components in place. I put my layout into a cad drawing but had no idea how the curves of the cable would figure in. How much would a cable curve? The thicker the cable, the bigger the curve.
It wasn't cheap but I bought the tools for crimping my own cables. In the long run, it may have been less expensive to do my own. Built cables aren't cheap.
What would you use for my setup?
I would go with the overkill.
Its pushing the limits but @OverkillSolar has tested the limits and demonstrated that he stands behind the product.
It will show current in and out and has all the desirable configurable parameters.
When I checked their site it didn't have 48v
I guess you could try them just make sure that the low cell and low pack disconnects are configurable at runtime.
And it it doesn't tell you the current in and out you should put a shunt on each battery circuit.
I don't think I need to bend the cable. And I can mount the busbars and on/off switch after the cables arrive.
But I am going to keep digging through information and decide how to handle it. I saw that I can order cables with the ends on them. But I don't know about different ends and rotated at 180 degrees.
I have been checking on the JK and I think it is fully configurable and some people really like it.
I will only order one BMS at a time. It wouldn't be the end of the world if I decided not to use one.
I see you writing some code in a lot of posts. What is that?
It's not code, it's a pure ascii way to describe system topology.
Thanks for asking.
If you are interested I can give you the 10 cent tour.
I guess I might have to do some experimenting and adjusting to keep my batteries balanced to each other. I want to put another BMS around the 4 batteries.
That doesn't make sense.
Do you mean shunt maybe?
I could see having 5 shunts.
1 per battery and the 1 aggregate.
A few people here use this BMS-
img_8357-png.20702
img_8358-png.20701
I meant another balancer around the 4 batteries.
That shouldn't be necessary. If you were putting the four batteries in series, then balancers for the four batteries might be called for. But your four batteries will be in parallel, so there is no need for a balancer. A periodic check to see what each battery is at (voltage, state of charge, etc) is in order.
