Smokey
- Apr 29, 2021
- 40
Im currently running 12v and using Victron a BMV 712 to as the primary BMS, with a Cerbo GX. I'm plan to change to 24v, when I tie in the solar, inverters, ect. I'll be installing a lynx shunt as the primary 24v system, and would like to use the 712 as a 12v "DC system" monitor since I'll have a buffer battery on it also. Is this possible to display on the Cerbo?
Edit: The 24v packs are DIY so a BMS for these packs could also be explored. looking into Batrium or REC, otherwise i'll be using 24v daly's
