I intend to start working on that soon as I figure out a plan of attack. I used the wrong word earlier when I said banned , as it said “incompatible “firmware ….I will go out in the morn and see what version I have . But whatever it is , I agree ,I need to update it.Mine came with 430, but I decided to upgrade since they added native low temp charge protection for Lithium batteries in 489. They fixed a bug that only applied it to the L1 inverter in a multiphase system, but now applies to all phases in 494.
Give that this is a new installation in the process of deployment, and that there have been multiple enhances with all VE.Bus inverters, I recommend you upgrade to the current 503.
one of the warnings they give is that if you do update it it will strip all clear all settings and they must be reset… ( or am I missing somthing) ? Why would that be ? Everything else the make I own doesn’t say things like that… it just updates and you go on your way…
at this point I only have the inverter on as there is no AC to feed the charger… the 150/100 charger is all I have powering anything…im going to rig a generator input to supplement the charging soon……i still have to wire a RV receptacle to feed the camper and a few other do dads …
it was late in the day when I finally tried it and I just stopped to think on what is next…
I was tired of being hunched over in a small tailor all day…
