Varney1241
- Jun 17, 2020
- 30
I just finished hooking up a 300 A Daly smart bms with BLue Tooth interface to a iphone.A smart charger will not give cell data.
I ordered this BMS from the Daly Store. It installed easy and worked out of the box.
There are so many options for communications I believe each one has a different firmware set.
So carefully look at the different configurations on Ali-express. I also ordered the BT module ($4) on the same order. The configuration is easy and i will post the config screens in the next couple of days. The low temperature cut off works and can be set from below freezing to well above.
I am only building a 2000 watt system but like all things electronic from China, there ratings are over esatated, Buy big/ build smaller.
