I full-time in a 50a Motorhome. After reading your messages this is where I would look - you may need to adjust a bit after doing the energy audits…
Two Multiplus II 48/5000. These will run a house with no problems.
Batteries- four rack mounted 48v 100ah batteries.
Look at Current Connected - they have “kits” that may be about all you would need.
Victron 10kwh Multiplus power system kit - plus battery kit + solar kit.
Also, if the fridge in the RV is the propane absorbing type - look at changing it out to a residential fridge. They work better - keep food better and use MUCH less electricity to run.
A smaller generator (or even 15 amps from the barn) can supplement when solar is bad.
Good Luck
Good Luck
