179 volts from five panels that (I think) have Voc = 32.9. I pulled that Voc from this spec page, but it could be a different model. It must be cold to get that many volts.
I'll go out on a limb here and say that the system looks good. The lack of sufficient sun due to snowfall and leaving the inverter on is the likely culprit. If some device was left on, drawing AC power through the inverter then that was the nail in the coffin. Without knowing the specs of your charge controller, I don't see a red flag, at least not in the wiring. The battery connections weren't made haphazardly. Someone put some thought into connecting the batteries in an optimal configuration.
Charging at only 8.6a is a killer. Total optimal panel production of 3100 watts down to just 8.6a out of the solar charge controller. Wow. It's going to take a long time to bring those batteries up to a full charge. Some monitoring needs to performed to see if the batteries ever do get fully charged.
GSXR1000, I saw your comment betting that they were wired in parallel. Man, wiring 10 panels in parallel is a lot of work. I can't imagine an installer doing that much work when a 5s2p configuration is a lot less time, effort and cost.
